Mopar "Crate Hemi Engine Kit"
StPaulSwinger
Active Member
St Paul, MN
I was curious if anyone has experience with the Hemi engine management kit (P/N177072455AB) straight from Dodge? The obvious surface appeal is that it's straight from the same people who made the motor, assuming you're doing a new hemi swap of course, it's made for dropping into a 70s Mopar, and it "should" work together smoothly. The two basic questions I have are:
1) are there real world reviews of this system (I've done a little googling without much success as far as end user reviews and not just magazine write ups); and
2) are you paying a huge premium vs piecing together a system yourself. I'm, theoretically at least, ok with a little upcharge for the convenience but not as much if it's a huge upsell without tangible benefits.
Appreciate everyone's insight as always (especially as someone new)!
I dont have any personal experience YET. But I'm about to start procuring parts for a 5.7 for my 68 and I've decided that's the way I'm going to go.
It comes with an unlocked ECM and reading through the 29 page installation manual, it looks like the loom has no unnecessary plugs or wires. Just what is needed.
It basically is a 2015 Challenger setup minus all the stuff we don't have on our old cars.
Very cool, I'm trying to be smart about my engine options and I've narrowed my list way down and one of the two remaining choices is the 5.7 so I'm trying to understand how many other pieces, beyond the engine itself, are required and what they cost etc. I don't want to spend money on name brands just for the sake of having it but there is definitely an appeal to going with something specifically made for your application.
I bought all my components for the 392 swap direct from the Chrysler dealer. Free shipping, warranty, and tech support, not to mention the parts mgr gave me his employee discount. I had an issue with the first 392 they sent (a long story but 168 miles into it #2 cylinder failed and I didn't even beat on her) so they sent me a replacement. No questions asked.
i tried looking for a price for this online but did not that anyone has it. Even Mopar websites came up zero.
Any resources guys?
Anyone know if it possible to just buy the PDC from the kit? Looking at modifying the harness from the donor car and use the PCM from the kit.
Based on my understanding, at least on the earlier 5.7 crate kits, the ECU was basically just a generic AEM ECU with 5.7 settings preinstalled. The harness was also tailored for the car. You could buy the generic stuff from AEM, though you would have to terminate the harness yourself and do all the ECU setup. It's not necessarily that hard, but it's probably worth the price of convenience to get it from Mopar already done.
That,s a factory unlocked pcm with emissions turned off. Works with 2013 and up motors, I believe
I purchased this kit to use on my swap. I've got a 2008 5.7L from a trcuk, that I'e converted to a car front end and intake. I'm determined to get it to work with a 2008.
ProTouringCuda read the last line of my post.
FWIW Just I just saw Year One is closing out one of their mopar swap kits.
P5153530AB
Mopar Performance Engine Wiring Harness, Programmable - P5153530AB
Also on ebay
Mopar Performance P5153530AB Engine wiring harness 392 6.1L 5.7L Hemi engines | eBay
Engine wiring harness for 392 6.1L and 5.7L EFI Hemi crate engines.
This is a stand alone engine harness designed to provide everything you need to properly wire your car in one simple configuration. Each master wiring harness includes built-in fuses and relays for fans, pumps, auxiliary power, and more.
  • For use with 392 / 6.1L / 5.7L Hemi with Production Intake and Manual Single Blade Throttle Body (P5153689, sold separately) and 2006-up Coils
  • 5.7L Truck Manifold May Require Wire Length Modification
Fyi, Holley just launched a hemi terminator system. Should all but kill the mopar controller kits unless "mopar" decides to discount theirs $300.
When these came out they were over $1500. The Year One price around $900. is a bit of a drop.
I know you guys are talking early tooth stuff...but These are only hanging around until depleted. Chrysler only sells the vvt engines now. I can't imagine the 32 tooth stuff being supported beyond current inventories. But for your purposes, they may do just fine! Didn't realize they were that cheap.
Ya Johnny,
Cheap enough that I thought about grabbing another one for another build in the future.
P5153530AB
Also on ebay
Seems a bit much for just a harness? No ECM?
No, not until they can get the x-Max for drive by wire out on the market.
