Stop in for a cup of coffee
Kind of petronix for some reason had meteric threads on the plate. Guy broke his original late putting the oem #10 screw in it. Could not believe it I almost did it also. it is for points mopar replacement told him to *****. Then it has a late ground recommended to go under the ca to a outside screw. Changed that looked like crap. They surprise me at times.
68 and prior HP had them usually the big blocks, not all though. Yeagh that was missing and never oiled. And has that big 67 on it. still have not figured that out not a year thing either seen all sorts of numbers. 83, 61, 43 etc.
Have a interesting one coming today superbird dual point has a early prestolight ignition set up wants to try to save it.:eek:
Just a example.
Man I have some stuff for you to sell if needed so you don't get thrown out. Tim the meter man!
You figure out what your doing for Carlisle yet Tim?
Well, I am going to be there......Probably tow another vehicle back there for "I forget his name". Your friend...
Other then that nothing....
You still want a rack set up for your Dists?
I'm officially ruled out for Carlisle. Brigade denied my request. We'll have to try and meet up on your way out for lunch or something
Cup #5.
Lots of coffee today. Just about have front frame rails beat into submission. One more plate to cut and a pile of weld to clean up. Once i get that done i can slather on some paint and install brake lines. Maybe front brakes by tomorrow.
If you can make it so it brakes down call me on that. Mark is his name have his number also if needed. He will be happy I am sure think it is a Blazer.
