Stop in for a cup of coffee
Put my pretzled bumper in the hydraulic press yesterday. The toughest thing to get rid of is the twist. Dents are easy, kinks are tougher. I left it to think of what i can do to untwist it.
I am sure that was fun on that bumper made of real steel!
If it makes you feel any better hoppy, you’re not the only one dealing with a cursed car. That mini starter I got and put on Polara, second hit and it doesn’t work anymore. Pulling it out and taking it back for warranty today @halifaxhops
The Polara isn't cursed, it's the ability of the mechanic working on it that's lacking.... LOL!
:poke:
Sorry, no exchanges on electrical items...
Drive through.... :steering:
Morning. -8 this morning. Temp will be dropping all day to -17 by 5 pm. Damn.
Work on fargo,measure for a couple fish plates and see if i can get them in..
Opposite here, starting at 18° F now and will get up to 31° for the high today... Heat wave... :D
Hook one end to something solid like a big tree. The other end a 30' chain hook the other end of the chain to the frame of your good truck. Back up as close to the end of the bumper as you can. Put it in forward LOW gear and then floor it. When your truck stops back up and check to see if the twist is out. If it is not repeat procedure until the twist is out. But don't do it in that frigid weather or the metal may crack
You got busted? That explains it then!:poke::rofl:
no, not busted, but they did screw up, promoted me, then realized they didn’t have the slot and after a year, demoted me as a “re org” and then randomly slotted next in that ranks slot but in a MOS I didn’t have, which left me stuck for years. And sad part, I caught them trying to do the same just last week.
The Polara isn't cursed, it's the ability of the mechanic working on it that's lacking.... LOL! View attachment 1715470526 :poke:
mechanic? Hell I need an electrician
Hook one end to something solid like a big tree. Put it in forward LOW gear and then floor it. When your truck stops back up and check to see if the twist is out. If it is not repeat procedure until the twist is out.
Repeat until the twist is out of the bumper or the tree falls.... Whichever comes first.... :steering:
Pronounced “electchicken”
Bumper is off. Wont fit the straigtened frame until i get the knots out of it. I have a tiger torch,will heat it if i have to.
