Paul King
MrPJK
The sway bar is missing off of my !966 Dodge Dart GT ,what bar will fit on it from another car maybe a duster would be the same .Thanks
ThanksThe 65/66 Dart/Valiant/Barracuda sway bar(if equipped) is the only factory bolt-in as long as you have the LCAs with the correct sway bar tabs. The factory sway bar is a hard animal to find as not all that many cars were equipped with them. Helwig offers an aftermarket bar that does require minor drilling of the K Frame to install and is much more beefier than the stock bar.
Yes it looks like it is missIs yours missing or did it not have one? Does your lower control arms have tabs?
If you have the tabs and you need the bar, start a wanted ad. Someone might have one for you.Yes it looks like it is miss
ing,But i will check again just to make sure
