Has anyone ever built a 318/340/360 to look like a 273??
I did it back in the early 70's, my 273 spun a rod bearing & I got a smoking deal in roll over taxi cab with a 360 & 727 with only 3200 miles on it. A guy I met at the drag strip was the maintenance shop manager for the cab company. It was amazing the difference between a tired 273/904 & a low mileage 360/727.
You can't swap intake manifolds from a 65-66 273 on any other year small block. There's a different degree of angle on the ports unless your changing heads too it won't work.
You are mixing things up a bit. 64 and 65 273 heads have intake bolts that are small, 5 16 using a 1/2 in socket, and at a different angle. 66 up are the same as all LA small blocks. All 273 and 318 ports have the same port opening, except for a few Pursuit 318s made in the 80s?.
OK Thanks for clearing it up I knew from having a 65 273 Commando in 1980 there was a difference that made finding an Edlebrock LD4B? almost impossible.
Another reason this site is the best GOOD ACCURATE INFORMATION ALMOST IMMEDIATELY!!! Thanks
We will find out soon how it works
1965 Barracuda 273, .030 over, Modified Edlebrock performer 318/ 360 intake.
