Accel Dual Point Distributor Question
694spd
Upstate NY
I have a small block Accel dual point distributor. It appears that you can limit
the mechanical advance by moving a small allen screw to different threaded holes that
are located under the breaker plate.
Is this correct?
If so does anyone know what the degrees limit is for each location?
I would ask Halifaxhops directly. He is a member here and quite versed in all Distributor aspects.
Good luck.
the mechanical advance by moving a small allen screw to different threaded holes that are located under the breaker plate. Is this correct?
Hello 694spd,
Hope this may May help.
Stay Safe.....
Happy Mopar :)
Arron
Thanks, Arron
That's the instruction sheets that I need, only I have some trouble reading them...
Thanks, Arron
Hello 694spd,
If you need PM me with your E Mail and I can send it to you in PDF.
Stay Safe.....
Happy Mopar :)
Arron.
