Jonnylightening
Hey guys awhile back I bought a set of EQ heads and threw them on my 77 LA 318. Over the past month ive been having problems. First off one of my rocker studs wiggled loose and i dropped a rocker and blew the lifter out of the bore. At first I thought it was a bad lifter (summit brand) but end up it just being the rocker stud. For piece of mind since it was apart I put a brand new set of Howards lifters in (hyd. Flat tap). This past weekend I got a popping sound comming from the engine. Turns out I broke a rocker stud. So i desided im taking my heads to the machine shop and get them drilled and tapped to 7/16 plus im going to run a girdle. I figured I should bullet proof it so it doesnt happen again. So upon taking the heads off I noticed my cam looked funny. Come to find out 4 of my 16 Howards lifters have concaves on them... Now before anyone asks I did do the cam break in to a T. I used almost a whole bottle of Lucas assembly lube, Howards zinc addative, lucas 10w40 Hot Rod oil (High Zinc), primed my oil and carburetor so it was instant fire up, and hit 2200-2500 instantly after startup for a timed 20 minutes. At this point im frustrated with hydraulic flat tappet lifters. So my question is what lifters (solid roller) will work with my 318LA with EQ heads? When I bought my hyd. Flat taps I used AMC style due to oiling.
