F/A Tech
Where do I start for most bang for the buck. Dual exhaust .... Headers ....4 barrel intake and carb !!
Thanks for the offer will see how we could get it to Canada.I've got a Edelbrock 1406 that Im no longer using that I'll give to you. It was passed onto me as a gift from another member and I upgraded to a AVS2. So I would like to pass it onto someone else. If your interested let me know. It ran great on my car, shouldnt need a thing, bolt on and go. I would say for intake look for an Edelbrock performer intake.
good on you why mess with it I also have a stock 318 in a more door and it works great it does have dual exhaustMy 1970 318 does just fine with no modifications needed or wanted.
What;Ede Performer intake.
Ede 600cfm carb.
340 HiPo exhaust manifolds.
Dual exhaust, hi flow mufflers of your choice.
Mopar Performance electronic ign.
318 I had back in the day. Called it the "Peg Leg Tire Roaster".
What;
no cam, no stall,no gears? lol
Was that a smogger-teen @8.0 Nominal Scr?
Just asking, not tryng to start anything....
Those were 9:1 I believe. Better than nothing and no big cam to take compression away.No, it was the original 318 in my 70 Dart. All stock bottom end. Original 2.73 gear. Day 2 bolt on goodies.
Most bang for the buck......
to do what?
Most bang, to get off the line, is a 2800TC.
Most bang, after already moving at ~20 mph or so (depending on the rear gear), would be performance gears.
Most bang, for Part-Throttle operation, or fuel-mileage, would be more cylinder pressure.
Most bang for passing, would be the right second gear ratio.
The most bang for a downshift into first at ~32 mph, would be a combination of Stall and gear ratio.
Most bang for spinning tires off the line, would be Stall, gears, and a 4bbl, all three together.
Finally;
Most bang for second gear power after 3500rpm, THAT would be a cam.
In order for the bigger cam to work, the engine has to be able to process the additional air. That means, more air in = more air out. So you gotta consider the 4bbl,the headers, the dual free-flowing exhaust, fresh cold intake air, AND the heads; ALL as a set.
see note1
Start with;
Ignition timing,then
Stall,then
gears and SG.
Next; 4bbl, and free-flow muffler, both together, then
fresh cold air.
Next;Compression ratio,cam/kit,headers,and dual exhaust; all together; or
solid lifter cam/kit, headers and dual exhaust; all together
Note 1
The thing about cams is, with no other changes;
the next one size bigger (a size being ~7*) same type cam (hydraulic FT in this case) will, at the same LSA, bump the operating range up about 200 rpm, at the expense of the lower rpm losing power.. So if you bump your operating rpm up say 3 sizes from the current 240*, to say 262*, your power peak will want to move up from ~4200, to maybe ~4800. but your heads will be hard done-by to make any power up there.
In any case if you gain 600 rpm at the top, then you will also give it away at the bottom...
So 600 doesn't sound like a big deal right? Well with 2.76 rear gears, the power peak moves from say 46 mph to 53mph , and that's a lot. Depending on your actual power, that 7mph,could be 2,3 or maybe even 4 seconds.
At the bottom, each cam size will cost you about 200 rpm in stall,so if your teener was fine with an 1800 stall with the factory cam, then the 3-sizes bigger 262 cam, will want ~2400.
So, when you think about cams,you just gotta think about the whole air in/air out,combo. see note 2
The LA318 is stuck with a pitiful 8/1 NOMINAL Scr. And that means it could be less, even 7.6. . So when a cam is considered, you also have to think about a TC, and the final cylinder pressure, and the rear gears; all as a package.
If you don't, you will have just joined the club of thousands of unhappy 318 owners who all did the same thing.
note 2
Here's how it works;
the typical 7.8sCR-318LA might make 135.33 psi @sealevel with the factory 240*cam with an ICA of 48*.
The next bigger cam, with an Ica of 51.5, drops the pressure to 132.22
The second bigger cam will drop to 128.35,
that's 7psi already!, or 5%.
But guys want to go straight to the 268/276, HFT 340 cam, with an Ica of 66*, and that drops the pressure into "Total Lazy-Dog"territory of 115.8psi/ a 14.8% pressure loss;Don't do that.
They all say it ain't so bad, but I tell you. it sucks/ don't do it.
Perfect. And it probably gets darned near 20 mph/ hwy.I added 2 1/4" dual exhaust (using the factory 318 manifolds & FlowMaster 40s), Edelbrock LD4B intake & 1406 carb, Lokar throttle & "kickdown" cables, Mopar Performance electronic ignition, and a Cloyes double roller timing chain & gear set to my 100,000+ mile 318, automatic transmission (A904), 3.23:1 sure-grip 8 3/4" rear end '71 Dart GT.
It's not a race car, but a fun ice cream parlor cruiser. Last summer our group made an approximate 1,000 mile road trip to St. Ignace (in Michigan's upper peninsula) for their annual car show.
Picture was taken on the north side of the Mackinac Bridge
Yep. Duals first because you will need them anyway. TTI makes hook ups to almost any manifold combination or header if you choose. 4 barrel and intake next. A stock Teen likes 500-600 cfm. Edelbrock, Holley, or even a old Thermoquad are good choices with a intake to match. Keep it simple. Electric chokes work well.The first thing to do is dual exhaust to let it breathe...
then 4 bbl intake and carb....
Replace the old timing chain with a good double roller, the stock 318 timing chain is junk...
