pearljam724
73 Duster. What is missing here ? Pointing at 3 holes on the column with a screwdriver
Could someone have mounted a tach there in another life? Just a thought.73 Duster. What is missing here ? Pointing at 3 holes on the column with a screwdriver
If that relay is bad or removed, Where is this light from the ignition switch? Shines through a hole in column or dash by the ignition switch ?Thats the ignition switch light time delay relay. Part of the AO1 light group.
Map light is bottom of dash pass side.
Oh, that’s what that thing is beside 4 way pull out knob, lol ? I can’t find turn signal relay for the life of me. Do these cars have a separate relay for 4 ways and turn signals like B body cars ? I found one on left of column for flashers. But can’t find turn signal flasher ? I have a AC car, so it’s pretty tough seeing in there.There should be a little cap looking thingy right in front of the switch. Has a little bulb in it.
Good God, no wonder I couldn’t find it, lol ! I completely removed the gauge cluster and still couldn’t find it, lol ! Thank you, very much for the picture. Air conditioning cars are a real pain in the ***, dash work related.On the pass side of the ash tray housing and one by the fuse box thats above the driver side vent box.
