Stop in for a cup of coffee
Good one.....
yeah.. sadly, that wasn't the worst story. the funniest is when they spent 58,000 dollars and 3 months designing a template made of high grade aluminum with special pins and bushings to be used as a drill template. They, the design team, finally get it approved. Have it made, only for the tech to go, "oh hell, i just used a piece of cardboard and drilled all those holes 3 months ago"...
Does the tire pressure look low???
994107501473_n.jpg?_nc_cat=103&_nc_sid=9267fe&_nc_ohc=xAUAiUXxZcgAX_irzBH&_nc_ht=scontent-atl3-1.jpg
I just got a random call (708-304-1150) and the guy is claiming that I hit his car last week... :wtf:
I didn't hit anybody's car last week... :realcrazy:
I told him to go **** himself and hung up... :icon_fU:
You did that all wrong, should have asked for his bank account so you could “wire him” the funds
Good Evening (your time), looks like you've got a bit going on over there today. I keep getting side tracked, had to do a branches run and some clean up. Finally got to pulling the Duster fuel tank. Have a question about the filler tube, wondering if the tank can (or should be) dropped without removing the whole tube. There's a rubber gasket I thought might slide off of the tube but hanging a little, don't want to force w/o knowing. Found out there's B5 blue up under the tank, that was a surprise, as was it feels and sounds like about a gallon of fuel in there still after at least 6 years not being on road. Here's pics, comments for the newbie please : )
I has a headache. So not so chatty. Paint fumes maybe....
