AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,923
- Reaction score
- 12,274
Slantys need 4-speeds; the extra, in-between, gear and smooth splits, will make her feel more powerful.
Ive got a 65 4 speed just sitting here withering away in my garage. Ill make you a good deal on it if youre interested.
Jake
HiJackers! Shall I tell you of my past loves?
Or...
At keep it about the Mopar ones!
Lol, well... I saw a Saw in Arkansaw one time...We’ve got time...let’s hear about your past loves. We’d love to hear it.
I married my first real girlfriend.
The others were just girls I encountered on the winds of time.
I see, said the blind man, as he picked up his hammer and saw.never saw that coming
I got the Countergear out and it looks like the pin has just enough Pitting/Discoloring to make me worry some.
What do You guy's think?
Yes, it's bad. Even with new needle bearings it will make noises and wear the new parts out.I got the Countergear out and it looks like the pin has just enough Pitting/Discoloring to make me worry some.
In that case, I'll bet the water washed all the oil out, and your cluster is fubarred too. At that point I'd be more inclined to throw it all away. And here's why;
If water got into the cluster, then the bearings and the pin will be toast. And the bored hole in the cluster, where the needles ride will be probably the worst pitted of all, and there is no coming back from that. You cannot buff that out, and even if you could, there are no oversize needles that I know of for that application. If you just slap it all together with a good cleaning, the cluster will fall down a few thou, forcing all the mainshaft gears to run on a different part of the cluster teeth. With the already compromised gears, this is just waiting for a disaster. It might survive a slanty for awhile but an overhaul kit with new bearings, is not cheap, and if it blows up in a week, you'll be a very unhappy camper.
I don't have another transmission... I have This transmission. I'm not wealthy, I'm broke.You should have passed on it based on the input shaft alone. I’d look for another transmission rather than rebuilding what you have.
Not only is the pin bad, the cluster-bore will look just like that. By this time it looks like you got almost nothing but the brass parts left to work with.What do You guy's think?
Okay, Yes of coarse you are right... :-(Not only is the pin bad, the cluster-bore will look just like that. By this time it looks like you got almost nothing but the brass parts left to work with.
The back part of the cluster is where the torque piles up; that is the most heavily stressed area, and every time you take off from a stop, that area is working hard.
I would not spend another nickle on that box, it will only make you broker
