4179425 90 Deg Adaptor LA 360?
That link you sent me, it says right on there does not fit LA engine blocks so is the 85 and later roller came engines not considered LA engines?
Are 85 and later roller cam engines considered LA blocks? Cuz the link you sent me says that adapter plate doesn't fit LA engines.
here's one. (removed)
the Canton on is very nice but 3x the price.
if you get a stock style one like the first one, drill four more holes in it between the others to help with oil flow
here's one.
Looks like I'll have to go with the $80 one. That first one for $30 is a screwed up website I can't get anyone to answer an email and they have no phone number. I tried to purchase one from their site and it wanted me to make a user account and when I did and entered my credit card number to buy it it turned up that I was buying something from MediaTek for $40 a month recurring. had to fight with them in my bank over it so I don't recommend using that 2040 parts.com
sorry about that, deleted the first link from my post. thanks. i just got the Canton one. very nice, worth it
You still need the LA adapter plate. Get a short spin on filter and sell the 90 adapter. You can clear most any header with a shorty filter and you got 1/3 of the gaskets to leak. Short filter can actually be changed, I had a hell of a time actually getting an HP-1 down to my 90 so I went with a remote.
Fram PH43 (stockish)
Height 4.047
Inside Diameter3/4-16
Outside Diameter3.656
Anti-Drainback ValveYES
By-Pass Valve Setting9-15
Turning Specification3/4-1
Base Gasket I.D.2.422
Base Gasket O.D.2.797
Base Gasket Thickness0.203
FRAM PH16 (shorty)
Height 3.688
Inside Diameter 3/4-16 Th'd
Outside Diameter 3.656
Anti-Drainback Valve YES
By-Pass Valve Setting 12
Turning Specification 1
Base Gasket I.D. 2.422
Base Gasket O.D. 2.797
Base Gasket Thickness 0.203
FRAM PH3614: (tiny)
Height 3.430
Inside Diameter
3/4-16 Th
Outside Diameter2.984
By-Pass Valve Setting12
Base Gasket I.D.2.450
Base Gasket O.D.2.760
Base Gasket Thickness0.191
Great info for me!
I think the plate is not the right convex shape from a Magnum, You can adapt by bending it with some creative nuts and some pressure.
