Anyone know if there's an existing thread where I could list the weights of some things I've replaced?
Searched, couldn't find one.
You should get aluminum weights.I took the lead weights off my wheels hoping to go a little faster but the car shook so bad I had to put them back on.........
Great idea!!! So how much weight would I save if I replaced 2 lbs of lead weights with 2 lbs of aluminum weights???You should get aluminum weights.
Strange Front Disc Brakes.......,,,32 lbs
Strange Rear Disc Brakes 30 lbs
Total 62 lbs
I have a 74 duster that has some lighter parts on it. I got the body with the interior already out of it. The hood bracing is taken out. Trunk lid is fibreglass as well as the front fenders. The 5 mph bumpers and shocks are replaced with 71 valiant parts. All stock type front end. Dana 60 rear. 470 stroker with alum heads and intake. Has a 14 point mild steel cage. 3100 lbs. Kim
Love those brakes ! I have them too. Truly LIGHT !
the car rolls some much easier with the strange brake...a lot less drag....
