Did all cars leave factory with a fan shroud? Or was it an option depending on engine size? Thanks Im wondering if my 1970 Dart came with one?
No. With factory a/c or heavy duty cooling.Did all cars leave factory with a fan shroud? Or was it an option depending on engine size? Thanks Im wondering if my 1970 Dart came with one?
Absolutely! Yo may need the biggest radiator that would fit as well. Good thing that generation of A bodies can handle a big wedge.Would one help with cooling a 440 in a 70 Dart?
The 1967-1969 A-body had the same optional shroud. I'm not sure if that shroud will fit a 1970 radiator. If you can confirm it does, there is a topic on these forums where a member modified his shroud to make it more efficient.I have a shroud I got from a 68Dart that had 383 in it factory. I also have 2 7 blade fans a standard fixed blade one and a thermal clutch type both 17 inch. Im hoping one of those 2 will work
IDK.1/2 in 1/2 out ?
