C2ndLTpigeon
Mopar or no Car!
I'm looking to hook up my pertronix distributor and coil. From the instructions it says positive wire goes to positive on coil negative wire goes to negative on coil my main question is the part on a coil instructions were it states to remove the ballast resistor to splice the wires together at a single point which wire's are going to which? And which wire is ignition going to the coil / distributor from the factory harness shown in the picture? Thanks
