bobscuda67
I'm using a Lunati VooDoo 702 cam in a 340 based 372ci engine. 220-226 degrees at .050 and I have Magnum heads with the 1.6 ratio rocker arms for a little lift bump. Edelbrock Air Gap intake and a 650 Eddy carb stock exhaust manifolds.
The 904 trans has a TransGo kit in it and a low gear set with a 9 1/2" 2800 stall converter. A 3:55 rear gear and a Detroit locker diff.
The car idles like a stock 340 but is shockingly quick thru first and second gear.
I miss 69 440 Cuda! I loved his post, they were so entertaining.
