Por15 sucks to do. It’s a work in progress so bear with
You are all Welcome to come find my place in Viet Nam......Good Luck There........Actually no... no one here has my actual address. They have the farm address and the other farm address.
ElectricI would run this one and also put in a set of Rhoades lifters:
Voodoo Retro-Fit Hydraulic Roller Cam - Chrysler 273-360 270/279
Are you gonna use a mechanical fuel pump???
Noisy. Do they make them roller?I run them in all of my engines... It's like having an adjustable cam...
Tim had enough trouble finding my place here hahaYou are all Welcome to come find my place in Viet Nam......Good Luck There........
As soon as I saw the half tracks I knew I was in the right placeTim had enough trouble finding my place here haha
Lol yeahAs soon as I saw the half tracks I knew I was in the right place
Scrap value is huge on thoseLol yeah
Not really. Around here it’s 85 dollars a ton. That’s about 2k each. As they sit, they’ve been appraised as recently as May for 89k and 73k respectively. If they were running, they’d be worth another 25-30k each. Fully restored with correct unit insignia and all the weapons mounts, which we have, combined with the German paperwork from then, about 200k-250,000Scrap value is huge on those
Running would be a plus....Not really. Around here it’s 85 dollars a ton. That’s about 2k each. As they sit, they’ve been appraised as recently as May for 89k and 73k respectively. If they were running, they’d be worth another 25-30k each. Fully restored with correct unit insignia and all the weapons mounts, which we have, combined with the German paperwork from then, about 200k-250,000
Love that pix! Kind of like my happy place! Hah!
My new happy place since I retired. LMAOLove that pix! Kind of like my happy place! Hah!
I know. I just like messin with you about um. I actually wanna try the Z-Max in something, but I'm not running a radical enough cam in anything.
Ok, well, since you put it that way.......
Electric
Eddie had Z-mas in his 340, but swapped them out because he didn't like the tick...
They were nice, because you set the 'gap' by bottoming out the plunger and then adding the clearance...
