dartfreak75
Restore it, Dont part it!
But maybe a good one. I am concerned about the break in procedure and getting the engine started quickly. My main concern was fuel. With a new tank new line new pump etc thats a long way for the pump to suck fuel before it gets to the carb ie lots of cranking! So I had a crazy idea that I thought about and I'm gonna try it, it can't hurt. I bought a cheap 5-7 psi electric fuel pump im gonna wire in to assist with the priming. I will hook it up inline with the carb bypassing the pump let is suckulate the fuel till the lines are fuel and the bowl in the carb is full then unhook it and hook the mechanical pump into the line and carb like it should be. Then the fuel lines as well as the carb will have fuel in them give the carb a couple pumps make sure its spraying and it orda pop right off as long as I have spark. What do yall think?
