New webinar Friday UPDATE
yellow rose
Overnight Sensation
Central Washington
AERA is publishing another OUTSTANDING webinar no later than Friday. It’s Randy Neil from CWT and he discusses over and under balance but he also covers a pretty good bit on harmonic resonance and dampers.
If you want to know why your crank broke or why the main saddles in the block and the main caps show fretting (it ain’t from detonation) then this webinar is for you.
I’ll post a link as soon as it hits my email.
Randy busts several well respected myths and wives tales. Worth every second if saving money is high on your list for your engine build.
I often wonder how they come to that conclusion. I have read that even mild detonation or poor combustion will loosen flywheel bolts and manifest as rpm specific vibrations leading people to think its a balance issue.
So tomorrow's Thursday. Where's the link, Butthead?
Seems the first time I heard it was in high school, and then I think the first time I read it was in Yunik’s book. I could be wrong as that was a loooooooooooooong time ago.
I watched it early this morning while drinking a pot of coffee. There was some pretty good info. Thanks for the link YR.
YR, I registered for the webinars coming up Jan 7-9 that you posted somewhere on FABO, but like a big Dummy I can't find the link. Could you repost, or bump the thread its in?
I will save the link this time!
I just got an email with log in info for the webinars, so I guess I'm good.
It can snow those days, and I won't even care..
