What size Pal nuts for my fender emblems?
nearpar
The Motor City
I was able to get a couple of nice Emblems on eBay. These used emblems came without the thread cutting Pal Nuts. I measured the studs with a dial indicator and got a reading of .133
What size pal nut do I need to attach these with 5/32? which is actually .1562
Thank you in advance
They might not take pal nuts. But the red plastic push in plugs. Do some homework first.
Common mistake to put pal nuts on them. The plastic plug are around $5 for a set.
Got the correct nuts on order thank you to all that helped...
