CORRECT pedal for 2bbl conversion
petty437
Kent, Ohio
Does anyone have a picture of the correct gas pedal assembly for the 2bbl (super six) conversion for an early (63) A? I want to use the floor mount pedal assy that just bolts in the original location just by drilling out the dimples already stamped in the floor. Thanks in advance! Tim
Cross posted in the Slant 6 forum also.
I’m thinking you might use the 64-66 V8 or 65/66 slant with factory AC bracket and floor mounted pedal for a 2 barrel conversion.
As explained here:
1963 Dart swap to cable throttle?
you cannot directly bolt a 64-66 V8 firewall cable throttle bracket to a 63 firewall. However, you can rig up something that looks like a factory V8 setup and uses the V8 accelerator pedal.
