That sure is an eye opener , thanks for sharing your findings.
I have looked around for Speedmaster Part 1. Do you have a link. I need to put them in the index thread. Thanksfor a change I didn’t have to deal will snowblowing my yard so I hit the shop and started on my sons Speedmaster heads then intake. I’m going to try to break down each post with pictures and maybe a little more detail to each area of the head so it will be easier if you want info on that area. First thing I did today was take both heads to my drill press to prepare them for tubing. I run a 9/16 drill bit through the two head bolts that run between all four intake valve. One on each head oils you rocker gear so these oiling holes will need redrilled at a later date. After I open up those two holes I run a 17/32 drill bit through the four pushrod holes that create the dreaded “pinch”. I then blow and semi clean the head for bench work. I cut four 9/16 part number K&S 141 (3.5 inches long) for both heads and eight 17/32 part number K&S #140 (2.750 Long) enough for both heads.
Thanks I'll mark it part 1. Let me know if there's another sequel.Lol. It’s already in there. I just didn’t know at the time there would be a part 2.
Speedmaster Small block porting tips and results
Thanks I'll mark it part 1. Let me know if there's another sequel.![]()
I find all your threads interesting! Especially the cylinder and intake threads. LOLAren’t you guys getting burned out on Edelbrock heads. I hopefully will be updating my moved pushrod Edelbrock heads very soon. They should be pushing 330cfm.
Some of his Walmart threads I could do without... I still think there needs to be an unwatch button...I find all your threads interesting! Especially the cylinder and intake threads. LOL
Probably some of my threads too. And for sure some of yours!
Personally, I never get tired of good technical threads. All the car shows on TV are mostly about TV drama. Your technical threads are just about "this is what I did in the garage today" and that is always good stuff. Taking pictures and posting it is a pain in the butt. So thanks for doing that when you can while working on your stuff.Aren’t you guys getting burned out on Edelbrock heads. I hopefully will be updating my moved pushrod Edelbrock heads very soon. They should be pushing 330cfm.
Well said Bob!Personally, I never get tired of good technical threads. All the car shows on TV are mostly about TV drama. Your technical threads are just about "this is what I did in the garage today" and that is always good stuff. Taking pictures and posting it is a pain in the butt. So thanks for doing that when you can while working on your stuff.
