thanks everyone for suggestions , had the got forked post, but had to pull everything apart to verify what was in car. nothing seemed to match and couldn 't get fork back in . I bought car as running project with issues. lots of money spent by previous owners. clutch wouldn"t fully disengage, it worked and didn"t slip but very stiff pedal and would clip gears shifting. so I pulled trans and bell to check everything. I bought new clutch setup with release bearing, just trying to identify bell , I have correct A body pivot and 12 1/2" fork . no numbers on bell and no block saver plate, also bell was never drilled at bottom of flange. might just look for factory bell if I can't figure out what bell possibe its lakewood 15320.
