PatrioticMopar
Active Member
Hey all,
After a separate post, I know I need to combine start and run power into a single wire for my ignition coil. I upgraded from points to an internal module HEI distributor.
I am trying to figure out which wires to combine. I will post a couple photos, if anyone can confirm... i feel like the brown with the eyelet is a run 12v and I just need to figure out what to combine to bypass the resistor.
Thanks again
Thanks again
