Paint or Natural
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Picking up rear end parts from stripper tomorrow.
67 Dart, 273, 8 3/4
Paint or Natural?
Housing - paint - semi gloss black
Center section - natural
Backing plates - paint - black phosphate
U bolts - natural
Shock plates - paint -semi gloss black
Pinion snubber - natural
Drive shaft - natural
Drive shaft yoke - natural
Pinion yoke - natural
Nuts and washers - paint black phosphate
Most of my deductions above were based on if the part was rusty or not, but many of the parts were bought seperatly so I don't know if many of the painted parts were originally natural. The ones with a ? After them I'm on the fence based on versions factors. Right now I'm just priming, so it will be:
black = paint
grey = natural
So what say you!
Depends if you're going for the factory look, anti rust or personal preference.
Shock plates were semi-gloss black, U bolts bare.
Backing plates were originally black phosphate. High Heat BBQ paint fakes it well...
Pinion snubber plates were bare steel
3rd member pumpkin was bare cast.
I was thinkin of you when I saw this. I thought you'd be a goodun to answer it and here you bees! lol
Looking for factory look.
Thanks for the bbq paint idea.
I assume nuts and washers would be natural or some form of coating.
When the kids get too old for a swing set...
(Just noticed I didn't get the shock plates black, dang)
VHT makes a paint called "Natural Cast"
I have used it on a few parts, and the color is real close to the natural cast iron. I used it to protect from rust.
