360 la vs 360 magnum rear main seal diameter?
1bad360duster
Hi I ordered a stroker kit for a 98 magnum block and was asked to measure the rear main diameter. I thought the 360 la and magnum should be identical? I don’t have my motor out yet so I can’t measure. Anyone have any experience or input? I did hear that the 318 magnums may be .01 smaller but not sure that’s true.
I have found out that there's a different seal for magnums, there are different part numbers & fitment call outs
If you look at enough listings you will find the rear crankshaft seal for LA 360 and 5.9L Magnum engines do overlap, somewhat.
If an older part number seal is found listed for a LA 360 but NOT for a 5.9L Magnum, it is only because the older part number never got updated to include the newer magnum engines. A newer part number, such as FelPro BS40651, is found in listings for both older LA and newer Magnum engines. So they do basically take the same rear seal.
I just measured a brand new 5.9L Magnum 360 crankshaft where the rear seal rides. If I did it correctly, the measurement was 2.965" using a micrometer. I also measure an LA 360 aftermarket crankshaft where the seal rides and it was 2.9634" using the same micrometer. So that is only about .0016" difference. Also, the biggest difference is the LA crankshafts have the ridges ground in for the old style rope seal, and the Magnum crankshaft is ground completely smooth without ridges, so that could be the main difference in the two sizes.
Find out from whomever is asking you for this measurement WHY they need it, what exactly they are looking for. I am guessing they are making sure you have the correct main journal size, not rear crankshaft seal size. A 5.2L Magnum or LA 318 would take a different main journal size than a 5.9L Magnum or LA 360.
Thanks for all the help guys. I ended up finding this today. The differences are within la 318/340 and magnum plus some stroker crank variants
