360 Magnum 6 Pack, serious eye candy
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Is this extremely cool/ sick or whatever?
From Vintage Speed
It takes three of the small throat
Rochester 2GC carbs
Adapts to any square bore intake.
I was looking for it and ran across the three identical carbs in flea bay fresh build for $200
Linkage was $90
Air horns the sliced bologna type were $100
With al the other custom stuff in my car it will be 1 in a 1000
I was worried that it was too long as you can see it’s a great fit didn’t want to cut the hood but it will be worth it
I’m crazy excited about it
I also found 6 Stromberg one barrels and I trying to figure out how to get a manifold for them
Only thing I can find that would be easy
Is a ModMan interchangeable tops 4 barrel, 2 four barrel, six pack. Take a top and cut a template and bore hole for six carbs
if its set up for square bore you could turn it side ways,..be a lil like a crossram set up but not!
that is a cool little piece
i wonder how well it would do, seems shallow and a few sharp turns
but if you can get it tuned in, it would be really something
if its set up for square bore you could turn it side ways,..be a lil like a crossram et up but not!
What a great idea. I was just telling dutmirage I
I hope I can, there might be a grinder purchase in the future
I’d bet that it won’t perform as wel as a 4 bbl
That’s okay I want it for eye candy. Shock value, bragging rights and it’s a delicious piece!! Very sick
View attachment 1715758787 The only gym I’mb in h I’mk ya on Very very sick !!!
I’ll be posting pics as the installation moves forward
That would be awesome i am excited to see it come along. What carbs are you gonna use? I was looking at the holley tri power carbs there not cheap! About 1500 for the set! Be nice if a guy could find a more economical solution for carbs. Lol
Looks like Rochester 2 barrels fit on that manifold.
I had the 3x2 setup from speedway motors on a roller 318 for a while had the 9super7 carbs. They are 125cfm each. With a stock bottom end a very mild reground cam 833od and 323 gears I got 26mpg driving to Carlisle, it was in a 47 desoto
Great the small Rochester 2’s are 278 x 3 equals 834 which will be plenty to feed my 360 magnum
Now recalculate to 4bbl. flow rates.
The Holley 6 pack Chrysler used is 1350 cfm as a 2bbl. When converted to the 4bbl. flow rate, they are 955 cfm. That’s a 395 cfm difference.
Visually interesting, but as far as any kind of increases in performance goes, I wouldn't expect any.
