turbofreek
batcrap crazy racing team
my coil wires have caps on each bank. they are not fastened down just dangling. i asked if they needed to connected to anything but nobody seemed to understand whar i was talking about. can be seen inaide the yellow circle behind the plug wires.i work at a cdjr dealer and there a bulletin on trucks that we would add capacitors in the asd wiring on the injector side and the the capacitors bolted to the head for rfi setting codes. i don't know if that would help on your build i know its not stock wiring or pcm.
