Over a tenth at the eighth, could have been a 13.80 pass.
Did you ever find out what rear tires she is using? And what pressure?Nice pickup in the sixty foot.
Does she know she should be leaving on the third amber?, she could probably deep stage if they allow it.
I think she’s doing just fine, and relatively consistent too, which is what is really important. It appears that she is getting comfortable with the car, which is a big plus as well. Is she manually shifting and running up the rpms on the brake at launch, or is she letting the trans shift at its shift points and staring from idle? Manually shifting and running up the R’s on the brake may give her a boost, but I’m glad she got her 13!
It’s kinda rough texting her through a night of test n tune on the phone. I knew she had her husband’s weather station so I started off telling her to take weather conditions and write them on each slip. Then she was heading to the burnout box to hot so to got her away from doing that. Baby steps but steps forward. Not trying to overwhelm her. If and when I get there I can stand at the line and get a better look at things. I’m sure we can improve that 60 foot time but not on the phone.
