I’m in. I like the idea of modifying that 72dart6pack posted also.I have the ones you need...you only need driver side...Mancini has the solid mounts to go on it
What is the next step?I have the ones you need...you only need driver side...Mancini has the solid mounts to go on it
The OP wants a 318 bracket. Not a 340/360 bracket.Copy this photo and weld it. Bam. 318 driver mount is now a 340 or 360 mount. Cost? A scrap piece of metal to Copy the other side of the mount as a template.
Next step if we are trading?I have the ones you need...you only need driver side...Mancini has the solid mounts to go on it
I’m the OP, I’m clueless, clearly.The OP wants a 318 bracket. Not a 340/360 bracket.
Great plan. I it’s in California currently.You better check your block first. Make sure it has all four lugs drilled.
Yes, that is the correct solid mount for a 72 down K frame.
^^^THIS^^^Copy this photo and weld it. Bam. 318 driver mount is now a 340 or 360 mount. Cost? A scrap piece of metal to Copy the other side of the mount as a template.
Okay.Never mind seems like too much of a hassle
Talk to brian6pac[/QUOTE
I am, thanks.
I’ll trade ya. KimAnyone want to trade my drivers 340 engine bracket for a 318 drivers engine bracket?
Bought one from Brian6pacI’ll trade ya. Kim
Thanks for letting me know. KimBought one from Brian6pac
