Motor mount brackets
Measure the ears on the block. They will likely have the same spread on both sides, that's 318 brackets.
As mentioned the X blocks I've seen use the easier to find 318 drivers brackets not the expensive 340 one.
The solid mount biscuits are the same.
This one?
You better check your block first. Make sure it has all four lugs drilled.
Yes, that is the correct solid mount for a 72 down K frame.
If you have a driver side 340 Mount like this one pictured I will trade you a driver-side 318 Mount that you need with a solid isolator
Anyone want to trade my drivers 340 engine bracket for a 318 drivers engine bracket?
Or sell me a 318 drivers side engine bracket. My time to be prepared is getting short.
