Stop in for a cup of coffee
Yes, i did. Machined a 1\2” bolt to 5/16, then flipped it around and drilled 5/16 into it. Cross drilled and tapped for the setscrew.
Thats great, I bet your shop is full of good tools to work with, keep up the good work working man :thumbsup:
So, new p/s pump and pressure hoses. Steering pulsates when turning the wheel. Going to send it off and see if it smartens up.
Hey All,
Noob question
Is there a listing or thread in here on local shops (machine?, mechanic? muffler? ) that members have used and been happy with as points of reference?
Hey All,
Noob question
Nothing specific but quite a few members ask. Go to the forum's list and start a thread in your regional area. You are probably in the South east region may be?
I'm actually conflicted on where West Virginia would fall in the breakout :) Probably more interactive with the Mid-Atlantic.
I'll kick one off!
Thanks for the idea TMM
Hey there Ray... Welcome in from the shadows :lol:
Sounds like a very busy visit.
Always is. He has moved 4 times in 7 years. Bought 3 houses only rented one.
He'll he bought a brand new house, two years ago.
Dad I want to put a patio in the back can you build me some decorative columns for the awning and a gate.
Then @Mopar Tim .and I drive down to El Paso. And deliver one of his cars that i had in my garage.
10 months later he moved to Ohio.:mob:
In fine military fashion.
My most annoying turn was moving cross country, buying a house and then 18 months later coming down on orders for overseas...
It was a nice trip......:lol:
I still haven't set the new floor down in the dining area. Did measurements and worked the numbers up this afternoon. Even going with poly trim and baseboard the material costs are pretty high.
New tie rods- Check
New Drag links- Check
New Track Bar- Check
New Shocks- Check
New Control Arms- Check
Unsolvable Death Wobble-Check
Registration for Jeep 100 mile off road cruise- Check
what could go wrong
New tie rods- Check
New Shocks- Check
what could go wrong
Most every time I have seen this, is with oversize tires. Non factory stock. JMO
New tie rods- Check
New Shocks- Check
what could go wrong
Usually not enough caster. Does it have a steering stabilizer on the steering linkage?
Looks like the sky leaked overnight, Was hoping to cut grass out back before the heavier rain kicks in this afternoon. Maybe it will be dry enough in a couple hours. Suposed to be a soaker through all day tomorrow.
I don't think the heavy stuff's going to come down for quite a while....
Morning fellers. Another busy day at the Toolman house. LOL Not nearly as busy as Craig though. Waiting for the garage door dudes to show. Time for a new spring and measure up for a new door. Laundry to finish and I need to get back to Mom and pick her laundry up and do it as well. My sister usually does it but she is laid up with a bad knee. (too much help for her daughters when they moved) Yep, she over did it and she isn't as young as she thinks. None of us are. LOL
So you're getting a new spring in the fall.... :realcrazy:
