James Camp
no mopar
Tried to use in 75 dart, didn't fit, vacuum controls with hoses still attached with color to know where they go. $40 plus shipping from 24248
Tried to use in 75 dart, didn't fit, vacuum controls with hoses still attached with color to know where they go. $40 plus shipping from 24248View attachment 1715177316
There was someone looking for a slide wafer box on the B body side.
Pretty sure these are the same other than the trim and fan switches.
is this still available? And if so can you post picture of the front. ThanksNope, slightly different.
thanks
The member that started this thread hasn't been on since November. Start a conversation with him (private message) by clicking on his name and then the conversation tab.is this still available? And if so can you post picture of the front. Thanks
Looks like what was in my 1969 Dart w/ factory AC. The 5-button pneumo-electric switches are available new and I think stayed the same design for years. I was following some for $75 on ebay, which is better than the ~$95 I recall paying via Paddock catalog ~1994. My Dart had that toggle switch. Both parts had melted due to excessive current (plus a little corrosion). I couldn't find a replacement switch, so took it apart and carved a plastic slide to replace the melted part. There is a writeup by someone on rebuilding the pneumo-switch. To avoid future melt-downs, I added a 30A relay which takes the load for the "blower high" position, which feeds full 12 VDC to the motor (no resistor in series). You can probably find an LED bulb which fits and shines sideways to put more light on the "light tubes".
In my 1965 Newport, I had more problems since it has a 4-button pneumo-switch which you can't find anywhere, and it also melted from high current. Apparently, those were only installed in non-AC cars (A's had mechanical cables). But, I rigged a 5-button switch to work, rearranging the vacuum tubes.
