pretty much what @Darter6 did to mine before he sold it to me
Man go for it, quit over thinking it. No guts no glory!I shouild have mentioned that the car has dual exhausts from the heads back, and I suspect it may have 3.23 gr as the car has a 7 1/4 SureGrip and launches better than I would think with a normal 2.74.
I'll be happy if there's a marginal performance increase as I'm still planning on doing the Isky E4 cam in the Spring. I just didn't want it to run worse than the 2bbl in the interim.
Thanks again!
Well, that would be like putting a screw in the slot on a holley vacuum secondary to make it open mechanically. You'd get a massive bog because of no accelerator pump on the secondary's@318willrun , wire back that 2nd carbs secondary air door and see if it helps any. If you check out the 1965ish Hot Rod article they did on the 273-8 that had dual AFB's...they did that for some reason. (im thinking it never opened enough otherwise)
unless you neutral drop it from 4 grandWell, that would be like putting a screw in the slot on a holley vacuum secondary to make it open mechanically. You'd get a massive bog because of no accelerator pump on the secondary's
Huh? There is no pump on the secondary of a Carter when those open either, nor a Holley VS. Its just a suggestion from an old Hot Rod article that I can't find at the moment. Perhaps it was set up as a progressive linkage.Well, that would be like putting a screw in the slot on a holley vacuum secondary to make it open mechanically. You'd get a massive bog because of no accelerator pump on the secondary's
View attachment 1715769742 View attachment 1715769743 View attachment 1715769744 Just for fun.. I really don’t know what someonehad in mind with this one. But, a “full house” LD4B. Plenum divider milled, and ported to probably the largest set of intake gaskets available at the time. I know nothing of the history behind it, other than it looks professionally ported. I’ve seen plenty of LD340 intakes with the same treatment, but not one of these. This one is in my “someday” pile, as in someday, I may have a set of cylinder heads that merit using it…
What a crude set-up for this 273, 65'. Dual quads, with stock exhaust manifolds!!! Remembering the NASCAR set up. Single 4 bbl on the 426 Hemi's in their NASCAR's and duel carbs on the production cars. I heard it was a way to slow the Hemi down. Of course, extra add-ons would make a difference. It's all in the complete package.Remember, the optional V8 for 56 Corvettes was a dual quad 265. Had 225 hp vs the 4-barrel version's 210. They were small four barrels, though.
Here's a dual quad 273 on the cover of Hop Up Magazine, June 1965:
A 500 is perfect for a 273. It's been a long time since I saw a LD340 so I can't say how closely the intake ports line up with the heads on a 273 which is a pretty small port. I didn't see where anyone mentioned that issue. With that, I advise checking with gaskets to be sure the mismatch is not going to be an issue. My last experience with a small block was my 318 which I ported and used a Thermoquad & intake from a 340 on. At that time I wasn't all that knowledged on what it took to make a quad work like magic. That came after I had graduated to BB's. So to make my point. My 318 heads looked like 340 heads with port matching work done. I later decided to switch to the smaller AVS 625 that was stock after the AFB's evolved. I used a factory iron 273 4BBl single plane low profile and took out the center of plenum, 4 holes and installed a 1 inch riser. Throttle response instantaneous compared to the thermo Q which wasn't bad until you floored it and hit the secondaries hard. Now, that I am smarter on thermo's I could have most likely fixed that, but who sees them anymore. They were not compatible with Ethanol mixed fuels which was why MOPAR used Qjets in the last years of that tech. The seals didn't last and they don't like sitting dry, among other things. Anyway, The LD is going to have larger ports than the 273 heads and unless you grind on the heads to match the ports there will be a sharp shoulder at the head that will interfere with flow and cause loss of performance potential !!!! It can affect throttle response. It is better to have a larger head port and smaller intake port. Personally at this point, I became a firm believer in the spread bore theme, I never had much success with any Holley spread bore, but Qjets and TQ's, I could make them work great, the small primaries worked awesome on everything for the street and the massive secondaries and high CFM just got it done for everything else when they were set up right. I would even try a TQ or Qjet on a 273 if I had the parts to build one now, but why when you can build a 410 now with stock looking parts and not spend much more than for the little motors. It doesn't make a lot of sense if you're building for performance. Mileage isn't going to make a lot of diff. if you drive sanely most of the time. Unless you plan on racing in stock class, which we all know is pretty much history now. I always wanted a supercharged car and the only way I could have that was to buy a blown up Pontiac 3.8 in a 2000 Bonnie and restore it. I love the 25 MPG or better most of the time and performance is fair, but IT'S JUST NOT WHAT ANY OF MY MOPARS were and bodies are just too hard to find anymore. I would part with my Bonnie in a heartbeat for a nice buildable Dart sport or Duster or any other style for that matter. I wouldn't even care if all the parts weren't there, I have other cars and stuff to drive until I get my Dream car running. I've had A's B's and E's and loved em all. Even had a 65 New Yorker for awhile which was replaced with a 72 Imperial Labaron 2 door. What a BEAST with a 440. Most BE U TE FULL car I ever been around !!!!!!!! In 45 years, I haven't seen another one like that one. Please tell me where I can find one of those, preferably Gold metal flake. Has to be a 2 door vinyl top. That front grill and those hind away head lights with wrap around chrome bumper. I want to put in a narrowed 60 rear and tubs for the most massive wheels and tires out there. Build a 572 Hemi with aluminum heads with twin dryers and install an overdrive auto built diesel tough. Add a Mega Squirt IFE and throw in a healthy doss of fast gas just for ***** and giggles. If I can't have this, I will have to settle for my 540 Cheby Aluminum head project which I already have most of what I need and find something to put that in. It's all up for sale or trade for nice MOPAR Hint coming 1972 Imperial Labaron 2 door, that hood by itself is like owning half of southern Florida and there for sure room under there to hide my dream engine. I can just see other peoples faces when it gets opened up for show and tell time. Yeah I still know this a supposed to be an A body only site but hell, A is the first letter of the alphabet and A would be a proper label for this project, a passing grade !!! Lets here anyone argue that point. After all you have A for all the under hood space, A for all the interior space, A for sure for those Montana sized doors and an A for all that real estate in that stadium size trunk. And those cars weren't all that heavy for their size either. Oh well, seeing as how only 2322 were produced in that style, it's not like I have a high chance of ever owning another one of those. Again, if I only knew then what I know now.I have an LD4B Edelbrock for my 67 Dart 273, and I'm planning on putting a cam in it most likely in the Spring.
Can I install the manifold and 500 cfm Edelbrock AVS2 carb in the mean time and expect the car to run reasonably or should I just wait.
Thanks.
The OP said he is using a LD4B, which is a 273/318 port exit sized manifold. They’re supposed to be one of the best small port manifolds that has ever been made. The Weiand Stealth is a nearly direct copy, but has been reported to have inconsistent casting quality.It's been a long time since I saw a LD340 so I can't say how closely the intake ports line up with the heads on a 273 which is a pretty small port
Nope. D4B's had the odd 64 and 65 bolt angle with 273 sized ports. The LD4B's had the 66 and newer style 273-360 bolt angle and the smaller 273 ports. (which also includes the 318 size ports) The LD340 is a little different runner design with the 340 (and 360) sized ports.I thought the LD4B was made back in the day for 340's and had 340 sized ports...and that it's the D4B, such as the one I posted, which have the 273/318 port size?
You're fine. We are here to teach and learn to advance the hobby.Wow, I stand corrected (and it's about time)!
I've been a Mopar guy since my teens in the mid '70's. I've never had an LD4B, but they have been legendary since I can remember...
I have had that D4B on a 318 in a '64 Valient that I drove for over a decade and although it was pretty normal to be asked about it, I was never corrected when I explained as above, what I believed to be true.
My apologies to all I may have misled over the years! I bought my D4B for cheap at a swap meet long ago, and I'm pretty sure the seller is the one who told me that story.
As for the manifold bolt angle, being aluminum, you can see the the bolt threads had just cut their own path a bit to correct their angle. I never thought too much about it even though it's been on and off the 318 many times.
Actually, I think this is good news, if I'm not mistaken, D4Bs essentially are LD4Bs with an easily correctable bolt angle!
Also good to know about the LD340...I always wondered if there was a difference, or if it was just a slang expression for LD4B.
Now I'm a little less of a dumb- a** than before this thread. Thanks for the schoolin'!
Thinking ahead. Or common sense.Just know if you put the intake and carburetor on now, it's all coming back off when you do the camshaft in the spring. Go for it. It'll run good.
You have to make your own.Anyone know where to get the beveled washers for the 1965 D4B intake installation on the 273? 65'
