Is anyone running 10” wide wheels on all four corners
Dan s
Tennessee
I want to run them on my 69 dart. If someone has this set up could you plz give the back spacing on them. Also. Pics are cool.
if I posted this in the wrong section. Sorry
Only if you are going for the Nascar look.
IMO 10" all the way around? You don't want those results...trust me. You'll never be able to turn and lifting the rear to accomplish the fit will get old quick.
Now, say OP wants to do it, what is involved? Mini tubs? shortened rear axle? OR shackles, crank the hell out of the torsion bars...:)
I would like to run the same size rim and tire on all four corners. Why? So it will corner better.
There are limiting factors on diameter in both too small and too large at that wide.
I'd say no on 10" with factory suspension on the front. You'd be looking for something in a 57mm offset if you've converted to BBP and probably need 18" more in diameter. 67-96 Dart's can't use some of the wider wheels with more negative offset that Duster and Barracudas can unless you cut the car, in some cases aggressively, like the 68' factory Hemi cars.
There is more to handling than rim width. What have you done to the car so far and how do you intended to dive it and where at what percentage of use? i.e. "dedicated track car 100% of the time, no street use."
Almost:
255/35/18
275/45/18
18 x 9.5 US Mag Bandit U109
You sold that heap, didn't you? I caint believe you did that.
I can't believe it either but pushing 70 makes it really hard to bend over a fender for hours trying to fix an engine problem. Getting under the dash is no fun either. I enjoyed it while I had it and I got good money for it!!! Now my son wants a 454 in his '46 Chevy.........I guess my mechanicing days are not over yet????????:mad::mob::soapbox::realcrazy::eek:
Damn man. Make him at least get a Mopar.
