[WANTED] 270 Red Ram right side exhaust manifold
Need a passenger side exhaust manifold for a 56 270 ci Red Ram. This is the manifold with the mount for the generator.
Just so I have this right, you're looking for a passenger side exhaust manifold for a 56 270 POLY engine? Since you said Red Ram. The Hemi was Super Red Ram. I don't know if anything, but I'm good at findin stuff and be glad to help you look.
It APPEARS the 241, 260, 270, 315 and 325 all take the same exhaust manifold to head gasket. So using some of those other cubic inch displacement might show up more results.
Yes the Red Ram is the Poly motor.
Nope.my 241 Red Ram.andnot a Poly. Sorry, no exhaust manifolds.
241 is a poly engine. Two forms. A poly head and a hemi head. Both are interchangeable. The same for the 270 and 315. I have dad's '55, 270 S/S w/od, it is the poly version. I sold my '55 Custom Royal Lancer, 270 Baby" hemi with At a few years ago. I have a set of 315 heads laying in the garage that would work. I have an exhaust manifold, #1553783-4, still has the tube on the exhaust for the choke. I also have a complete '53, 276 Desoto engine in pieces minus valve covers. Each division had their own poly and hemi engines. For the most part they weren't compatible with each other. Distributors would interchange, as they will with the later LA engines. I'm running a dual point from a '56, 315 hemi in my '69, 318. Had one in my '69 340 also. If interested LMK. Q
