Well that'll be a boat load of fun. I'm starting to get all the parts to put a World Class T5 in Vixen.Tremec TKX. 5 speed.
I hope so. I never really cared for the three speed auto. I've always liked manual shift cars. I'm just hoping I can sell the 727 once it's out.Well that'll be a boat load of fun. I'm starting to get all the parts to put a World Class T5 in Vixen.
Take plenty of videos with good audio and I'm sure it'll sell.I hope so. I never really cared for the three speed auto. I've always liked manual shift cars. I'm just hoping I can sell the 727 once it's out.
Whine on coast is the pinion is too far away. KimNoise on decel is either too much pinion depth or too little, I can never remember which. You might try dropping the drive shaft and see if there's any slop at all in the pinion yoke, as if the pinion nut is trying to back off. That's actually a pretty common issue. What casting is the case? I "THINK" I see "742" as the last three, but I'm not sure.
Pinion bearings make a whirring noise when ur picking up speed. Silent when off the gas. KimI understand the concern now. I would check it out too in that case. It might be a pinion bearing going out and now's the time to catch it, before any other damage is caused.
I did. It was low so a quart was added. The noise is still there.Check the diff fluid level>
I saw it too but thought it was normal. But then again, I know very little about these things.Did anyone else see the pinion jump up sorta when first put into gear.....................or am I losin' it.
Thank you drive through.Pinion bearings make a whirring noise when ur picking up speed. Silent when off the gas. Kim
If the pinion jumps separate from the housing, that's an issue. I didn't notice that. I'll go back and pay better attention.I saw it too but thought it was normal. But then again, I know very little about these things.
Yes RRR, you need to learn how to pay attention!!!!If the pinion jumps separate from the housing, that's an issue. I didn't notice that. I'll go back and pay better attention.
New neighbors. I talked to them a bit later. Cool people.Your car must be loud or really good looking... You neighbor came out and checked things out (0:45)
I'm trying to track down a "whining" noise I can hear when driving. I put the car on jack stands, lifted the differential, and ran the car up to about 40mph, trying to see if I can recreate the noise. I didn't hear the whining sound, but my driveshaft jumps at the :37 mark. Thoughts?
A bad transmission mount would cause the front to move with the tail housing.I thought it might be the 1/2 shift too but since the rpm didn't change, I wasn't sure. I guess the car has to be under load. Question. Is the driveshaft jumping normal or is the transmission mount the issue like the first reply said?
THANK YOU! I can never remember that. lolA ring and pinion that whines on decel is too far apart; whines on accel; too close.
