In stock. Dr Diff Offset Hangers
go-fish
Finally! I missed out the last run of these so I’ve been watching everyday on his site.
Just a heads up. They sell out quick!
The same guy who measured the pulleys for us bought a set last Thursday or Friday. They are going quick.
I know a lot of guys run these with good results.
How do they affect handling? It seems like moving the springs in board would require higher springs rates or a stiffer sway bar to maintain the same roll resistance…
I would be interested in knowing how much handling is affected by doin the full inboard relocation that goes into the frame rails in the front. Shocks go more vertical than angled.
Dr. Diffs is a 1/2". I wouldn't even spend time on the thought. The shock angle barely changes. THat 1/2" probably has very minimal affect on handling but allows you to maximize tire without cutting any metal.
I've never not run offset spring hangers, so I can't compare it to a stock setup. I'd be willing to be there is no difference. Now, the 3" offset kit for a handling application may not be the best idea.
