Trick Flow small block heads
I was too busy with working on mine and my buddy's cars to even go to the track this year. I mini tubbed mine and put in caltrac suspension and a dana 60. I then decided the 295 55 15 tires weren't going to cut it so I ditched the stock gas tank, moved the rear back and more trimming to fit 315 60 15 drag radials. I will have the engine on the dyno in the next couple months so at least I will have numbers with them.
All I can add is I just order my second head. It’s backordered till late December so hopefully I have the first head ported by then and my valve, seat machine running in case I want to go with bigger valves.
not sure if I read whether you got the second head or not?
Hope you are feeling better, looking forward to the results.
Thank you very much and I have been. I ran the snowblower for 4 hours last weekend and 2.5 hours today. And on hilly property with all gravel that can beat you up. Then I spent three hours in the shop. I just wish it was nice enough to start walking again.
