Idaho fish
Active Member
I am getting ready to order a wiring harness kit for my 68 barracuda. I am finding out I need to change from an ammeter to a voltmeter. How do I do that while keeping the stock gauge and have it read correctly
Interpretation: All the waterways are frozen and I have cabin fever!I guess snobsixdan doesn't bother to read before posting
Thanks for the info, I think I found my solution. On my 68 it has a blank gauge hole where the performance indicator is on my 67. I can put a voltmeter in there without having to mount on somewhere elseThere are still plenty of those Sunpro voltage gauges floating around. There are five Ebay sellers offering them right now. I got mine from this place, good price, fast and free shipping:
Sunpro 2" Voltmeter 12V Black / Black Bezel New CP8215 Authorized Distributor | eBay
Sunpro was acquired by Bosch several years ago, but it looks as if Bosch is offering the same or similar gauge still under the 8215 part number. It's available for less than the price shown at many resellers.
Electrical Voltmeter Automotive Gauge | Style Line 2”
That looks great, I will probably still use the blank hole for the voltmeter and leave the ammeter unhooked. But if I did do what you did it would allow me to put a tach in the blank hole.I will have to do some serious looking at it and study everyone's comments before I decide how to do itI never got around to posting a thread from when I did mine. I overhauled my cluster 2 years ago & swapped a SunPro voltmeter in place of the ammeter as part of doing some electrical system upgrades.
It took a bit of finesse & mods, but I overlaid the SunPro gauge [round] faceplate on top of the ammeter faceplate. The sunpro faceplate is a bit more glossy black, but I'm satisfied with my results. Not a job for a novice. Here's a few pics...
View attachment 1715859521 View attachment 1715859522 View attachment 1715859523 View attachment 1715859524 View attachment 1715859525 View attachment 1715859526
If its stock then its fine. That system worked for 100 of thousands of cars. Add a relay circuit for the headlights. Why? because the original lamps were rated 40/40 Watt. Since the 70s replacements draw more. Bonus of using a relay harness is that reduces the maximum possible load through the R6 wire by 9 amps. I'd say the biggest issues are condition of wires and connectors. That most certainly includes the quality of the repair and replacement work. It also includes good wire routing and support. I, like many others, didn't give those last two much respect as young shade tree mechanic. But thats a big part of why wires and junctions survive long use without damage.Still learning. My all stock '70 340 Swinger 340 needs some safe upgrades, while appearing stock. You electrical gurus rock. I'm familiar with installing wire bundles, and have an O'Scope, but stuffing a TF 408 in a stock wiring system ain't going to cut it. I've learned a ton of electrical information from all the members here. I bought a sheet of 4X8 plywood to make my own harness with upgraded wire gauge and connectors. More to follow.
I am going with a new wiring harness from classic industries, it is supposed to match up to the stock system except for the ammeter issue. Hopefully I will be able to figure it all out. Its a long term ground up project so I can take my time and study things out as I goIf its stock then its fine. That system worked for 100 of thousands of cars. Add a relay circuit for the headlights. Why? because the original lamps were rated 40/40 Watt. Since the 70s replacements draw more. Bonus of using a relay harness is that reduces the maximum possible load through the R6 wire by 9 amps. I'd say the biggest issues are condition of wires and connectors. That most certainly includes the quality of the repair and replacement work. It also includes good wire routing and support. I, like many others, didn't give those last two much respect as young shade tree mechanic. But thats a big part of why wires and junctions survive long use without damage.
If you really want to do some reworking, again assuming stock loads, then copy one of the 'fleet' or 'heavy duty' wiring schemes. A parallel wiring is another approach, which is similar to the 'heavy duty' scheme used on 70s models with rear window defrost grid.
The voltmeter in the cigar lighter is OK for an occassional check. Check your year for where in the fusebox that is wired to. ;)
Sure don't want a slow drain! Thats exactly the type of thing that causes high battery draw and damages stuff!
