dartfreak75
Restore it, Dont part it!
So all the factory magnum stuff interesting. Are the 318 magnum heads any count ? I have a spare set of them I believe.oil through pushrods and lifters.
magnum heads are the same, no matter 5.2 or 5.9. You cannot just drop magnum roller lifters and pushrods in a '76 LA motor and have it work. Depends if you are using a roller block or FT, the length the pushrod will vary.So all the factory magnum stuff interesting. Are the 318 magnum heads any count ? I have a spare set of them I believe.
I have a roller 86 318 block. The roller lifters from the magnum will work in it right?magnum heads are the same, no matter 5.2 or 5.9. You cannot just drop magnum roller lifters and pushrods in a '76 LA motor and have it work. Depends if you are using a roller block or FT, the length the pushrod will vary.
should be just fineI have a roller 86 318 block. The roller lifters from the magnum will work in it right?
Im not a professional engine builder by no means and im still learning as i go but one conclusion that I have reached and I may be wrong but flow trumps compression imo. I wish I had the money to prove my theory but I believe a well breathing properly tuned 8.5-9:1 engine will out run a 10.5-11:1 constipated one.If compression is equal, am I alone at liking open chamber heads ? (I shouldn't have asked... lol). I am attracted to the rocker arm shaft assembly of the LA. However, I have not had a bad experience with the magnum set up. To be honest, I think either head would be a nice improvement and work for the build.
flow does trump compression in a racing applications. However, flow with compression is ideal.Im not a professional engine builder by no means and im still learning as i go but one conclusion that I have reached and I may be wrong but flow trumps compression imo. I wish I had the money to prove my theory but I believe a well breathing properly tuned 8.5-9:1 engine will out run a 10.5-11:1 constipated one.
Yep. I'm no expert either and haven't experimented much like 318WR does but you need some compression. The Teens weren't high compression engines and if you bolt on a set of heads with a big ol' open chamber designed for 4" bores and use a thick ol' head gasket and throw in a big ol' cam with lots of duration (that bleeds off compression) you might have to spin it to 5 g's or better to make your big port heads to flow. Whew, that was one long sentence!flow does trump compression in a racing applications. However, flow with compression is ideal.
Yes I agree. The whole whole forced induction movement proved it to me. They can take low compression engines and make big power with forced induction and all forced induction does is increase flow in a forced manner lol I know it apples and oranges and alot will disagree but in a nutshell its the same thing if you increase flow whether it be with ported heads cam intake and exhaust or pushing/pulling boost down the engine its still increasing flowflow does trump compression in a racing applications. However, flow with compression is ideal.
In a sense, yes. However, most out there are cracked and the engines are running fine. I'm not saying cracks in the head are fine, but it doesn't seem to effect anything.
I would certainly take them apart and inspect them prior to use. I wouldn't put a bunch of money into them either. I do have all new valves for a stock magnum heads, springs too for that matter but they aren't the springs I'd be using anyways. I'd probably just buy new bare castings and put my new valves in them IF the magnum heads were the sure way I was going.For me, it’s a tough sell to have someone spend money on heads that are visibly cracked.
If you’re lucky enough to have a pair of them that don’t have the exhaust seats sunk down into no man’s land, and can get away with a very minimal amount of machine shop servicing........that’s great.
But if they’re cracked, and they need some seats and/or some guides installed........ do you really want to spend the money for that on castings that are already cracked?
I guess I’d(meaning you) have to assess the actual condition of the magnums you have on hand before I decided if they were a viable option or not.
Yeah, I usually pour rubbing alcohol into the ports and see if any gets past the seats over the course of an hour. I sometimes I shine a flashlight in the port in a dark room and see if I can get a sliver of light around the valves.Generally cracks in Mag heads are easy to spot after a good wire brushing. You can also spray starting fluid on them and watch the area between the seats. It evaporates quickly, but will stay in the crack a might longer.
I've pressure checked a few Mag heads that were cracked and no leaks, but like PHR said, I wouldn't try to sell any work on them.
To be perfectly honest, I'm leaning towards the LA 360 heads due to the fact I have 273 adjustable rockers/shafts and if I go solid roller, that would put me miles down the road cost wise.
I agree IF the compression is the same, it is a toss up.Performance wise you've had both and have done quite well with both. I think if you do one of your mild port jobs it is a toss up as to which is better.
I'd like to go solid, and if I do, I'll most likely build my own solid roller lifters. First, most solid roller lifters are for non-roller blocks. 2nd, the price for solid roller lifters are incredible!.Solid Roller! Now you got my interest!!
Don't forget the industrial stuff!Everyone always says "360 heads will kill your compression blah blah blah" but they fail to realize the only factory compression boosting heads for 318s were the 920 heads from 1967 and they well famous 302 heads. 360 heads all the way with a cheater cam (like the Comp 270) to build cylinder pressure and make up for the low compression.
A lot more likely to get quench effect with the magnum chambers vs an open chamber. Less likely to detonate, more efficient combustion.
what size solid roller you thunk'in????? would love to see details on "building" solid roller lifters,..im guessing from factory hydraulic roller lifters??I'd like to go solid, and if I do, I'll most likely build my own solid roller lifters. First, most solid roller lifters are for non-roller blocks. 2nd, the price for solid roller lifters are incredible!.
