440outlawdart
are those mopar performance aluminum heads
If you use the B-body manifold, would you share the modifications needed to fit your application. TIA
He's a good dude for sure. I'm likin what I'm seein! Lots of cool old school stuff. This things gonna haul the mail!Driver side manifold was on the shop doorstep this afternoon! A sincere thanks goes out to Jim/fishmens67 for donating a very nice specimen. I will take some comparison pics when I get back out for "2nd shift" aftrr everybody goes to sleep. What can I say, vintage cast iron gets me excited.
Nice car, I like the ruff look!
What are you running for a clutch, bell housing, and rear end (with ratio)?
I'm thinking about building a similar set up.
Thanks for the pictures etc!
Nice 361 !![]()
The clutch is a borg&beck style 10.95" RAM Powergrip HD:
Powergrip HD Clutch Sets Archives - RAM Clutches
Everything they say in the description is true lol:
“strip/street” competition clutch system that can handle the rigors of weekend racing and spirited street driving. This system has the same components as standard POWERGRIP above with the exception that the disc friction surfaces are both sintered metallic. Sintered metallic provides a degree of slippage on vehicle launch to prevent the violent and uncontrollable engagement characteristics of paddle type metallic discs. This firm consistent engagement is easy to control. Some chatter is likely on engagement with rear gearing less than 3.73 in street applications. Each set includes the pressure plate, clutch disc, release bearing, and alignment tool unless otherwise noted. Use Powergrip HD for power levels to 650 horsepower, or lower powered vehicles that see frequent track duty."
The bell is a Quicktime 6073. If you use this a) the factory bb z bar pivots work and b) it needs a few modifications as follows 1) the clutch fork pivot folds up and 2) nuts should be welded to the back side of the pivot bracket to aide in keeping your sanity upon assembly.
Also verify the holes on the bell match the holes in the supplied block saver plate. DAMHIK on that and the pivot fork bracket.
Rear diff is the original 8.75, 742 housing with 3.23 gears. I added .100 to the clutch pack when I rebuilt the sure grip unit. A Dana 60 will replace it when the 499" deal goes in.
Any other q's feel free to ask. I love sharing and chopping up build plans and other gearhead data.
do you still run the overcenter spring with that clutch?
Did you get a good look at the manifold, any comparison to the others you have
Do you think the b-body manifold is going to work with your application ? 4sp
Any updates on the manifold fitment?
