[FOR SALE] 8 3/4 Ring and pinion set.
triumphman
Oklahoma
This set was just replaced with a 3:55 gear set due to 75mph on I 35
Does not make any noise. There is no wear on the gears.
Ships from 73044, Guthrie, Oklahoma
$125.00 plus shipping. Postal Money orders only.
Interested, but what brand is it and what case is it for?
...and why does it say 3.91 on the box?
I'm also interested, but I have the same questions as the others. Please confirm the ratio and what case it fits.
Looks like a 741 application. No step feature used on the 742 and no taper as used on the 489. At least from what I can see from the pics.
The numbers on the gear is info you can research and determine who manufactured them for the factory in 1969.
Be a lot easier if the seller had a less confusing and provided more info and better pictures....
The item: Factory ring and pinion gear. 3:91 ratio
Fits a 741 case. 1 3/8" pinion shaft (straight shaft)
Shows no wear on the gears.
I had a set of 3:55 ratio gears to replace the 3:91.
Where I live, "Interstate" I-35 is 75 MPH (miles per hour) Most run at 85 MPH. So, the 3:91 is a bit too low.
$125.00 plus shipping charges. USPS only.
Interested in 3.55.
Mistakenly thought OP was listing 3.55 from the text.
Glad that's been cleared up.
Please continue without quoting me.
Thanks.
