[WANTED] SB 2bbl intake
mopops
dutchess co ny
need 2bbl intake for use with rotary A/C compressor 318 or 360 . i want it to convert my 81 imperial from fuel injected to carb. the older intakes have the heater hose located by the stat housing an no tks bolt hole for A/C bracket
I have one from an 86 5th Ave
Is your engine an LA or magnum, the bolt holes are different. If you have an example(photo) that would help.
Your mail box is full!
I've got an early 360 2bbl intake, but you might want to get a 318 2bbl for a better port match.
I got an old 318 2bbl yours for flat.rate game box shipping. What AC bosses you need?
Just a heads up- sometime in the late '70s they also moved the thermostat housing over to the driver's side to help with clearance on the new compressor, as opposed to the more centrally located one on earlier manifolds which interferes with the later brackets and compressor.
Newer manifold (I know it's a 4bbl., but you get the idea):
Old manifold:
One thing you might consider; keep your TBI manifold (you know everything fits) and use a 2 bbl. to TBI flat plate adapter to mount the carb. There's some out there, or it wouldn't be too hard to fab one up, either.
up tks
LA 1981 318
Old manifold:
tks will look for adapter plate
I think I sold my last 2 barrel intake for $35 but shipping was over $40.
If you decide you want it, please respond here with "@YY1" and I'll clear out a PM spot for you.
I have one off an 86 318 it will need cleaned up but your welcome to it if you want it
mother mopar made a kit to replace the intake etc. i remember seeing a video years and years ago with a parts list/pic of everything needed. google search maybe.
my in box is full and i dont know how to empty it i want to buy the manifold
Go to the top right hand corner and click on your inbox. Go to all conversations and then leave the conversations you want to delete.
