[Found!] 1965 Small Block TorqueFlite Pushbutton 727 Transmission
Yeah I had one. I think it was the only year for push button and slip yoke together. I still have the valve body. Stripped the rest out for parts. Its one of those things nobody wants until that one guy is looking for one.
Me too. I just stripped one for parts..... So, I have a bare case if it gets you started lol. Far away from you tho.
TRANZ ID #'s 2466111 and 2466152 and 2466166 and 2466134
My issue is that I have two good 1964 ball and trunnion pushbutton 727s, but that means I have to figure out how to have a suspension shop splice in a ball and trunnion into my driveshaft. I thought of swapping in a 1965 pushbutton slip-yoke output shaft and housing, if I can find one, but I'm told they will not interchange with 1962 - 1964 727s. I don't know about that since they are all dual pumps. I guess that might be worth a thread. At the end of the day, it might be easier and cheaper to a shop splice in the ball and trunnion and locate a proper front flange.
I have not ever heard that... we'll see what others say. I think you could use any '65 trans, for small block or big block, and just remove the output shaft and tailstock to use on your BnT units.
