Can someone tell me about the cam specs below, I need a cam to get a car going, and would love to get an Oregon cam but don’t have the $750 Aussie dollars delivered at the moment. In the future yes but for now, will the below do for a 2bbl, bbd carter and 2 1/4 inch exhaust and 9.5 comp
Camshaft Lift INT/EXH - 0.270" / 0.275". Valve Lift INT/EXH 0.405" / 0.414"
Deg Dur @ .050" INT/EXH - 198 / 202. Deg Dur @ .006" INT/EXH - 272 / 260. Lobe Centre INT/EXH - 107 / 111. Lobe Separation - 109.
Timing @ .050" INT Open - -9 BTDC. Timing @ .050" INT Close - 27 ABDC. Timing @ .050" EXH Open - 31 BBDC. Timing @ .050" EXH Close - -9 ATDC
