64 Valiant Slant 6 Fan Shroud
RustyRatRod
Caput villa stultus
Georgia
Did the 64 Valiant slant 6 ever come with a fan shroud and if it did was it even worth adding? I've seen some I "thought" might be correct, but they were nothing more than a circle made from what appears to be no more than a strip of metal only about 1.5" wide if that.
I can't recall ever seeing one on a /6 early A, but I have seen several of the sheet metal fan shrouds that were exactly as you described. The dang shrouds weighed as much as the radiator!
I think I am going to either make one, or modify one. No over heating at all, but I am getting ready to swap to a better fan and smaller water pump pulley "just because" I have them and I thought I might add a shroud, too.
I have a factory slant fan shroud for an early A with the brackets for mounting to the radiator. No idea of the part numbers. I can check on the numbers and get pics when we get home. Am currently in Switzerland. Leaving for Sweden, Finland and Estonia before returning to the US the end of then month. PM me if interested
I know it has been a while since this thread was active, but I thought I would try anyway. Did you manage to find the part numbers?
For the 22" radiator in the '65-6 models, the upper shroud is 2524501 and the lower is 2524508.
Here is a poor picture of one from my 63
'64 was the last year for the ring-style shroud shown by bschief. Starting in '65 it was a box-type shroud, still made of metal, still in two pieces (upper/lower).
