Branden Finkenbinder
Member
Hey everyone youngster here about to built a 1970 318 for a 1965 dodge dart gt 2 door. the dart will be a all steel car 4 speed with 4.10 or 4.88 gears 8 1/4 rear stock suspension other then front disks as for motor it will be built as the following
1970 318 stock bore
KB 10.5-1 pop up pistons
273 hipo rods or some form of a lighter rod
318-3 truck crank
0.27 head gaskets
1965 273 hipo 54cc closed chamber heads with
adjustable rockers Ported as far as I can with out thin walls both exhuast and intake 3 angle valve job with 1.88 360 valves
Solid mechanical camshaft good for 7500 and up rpms
273 4 barrel intake or a d4b intake if I can get one cheap enough
Holley 750cfm double pumper
Just would like to here yalls input from those who are wiser then me as I'm only in my early 30s and this is my first on my own build
1970 318 stock bore
318-3 truck crank
0.27 head gaskets
