that is compatible with factory mopar ignition? All I see available are the ones that require use of MSD ignition. Thanks.
There's at least 1 dedicated product but it "may" require a dedicated distributor. I don't pay attention to this stuff because it is so expensive. The ones I've seen, support mgpmike above. You are well on the way to buying an EFI controller by the time you pay for an "ignition only" device. A guy has to wonder, "without EFI, then why?"
You could probably use the MegaSquirt MS2 or MS3. Inexpensive, just don't need the fuel control. In addition, you could use the spare I/O's to run an electric cooling fan or something else cool.
MSD used to make a stand-alone unit, pn 8680 I think. I see now that they say it must be used with their controls. I bet they just say that because of the connector style. But IDK that. I would call them.
I bought one to use on my car, but I sold the car before I ever got to try it. You can pull out up to 15 degrees.
