or a bolt and nut in the slot?
It is a cheater for not having the right length slotted rod.What is the nut and bolt in the slot do?
I see. I have the right piece of slotted linkage, but have an an Edelbrock RPM intake and 1406 carb. Originally the car came with a 2 barrel carb and it still has the short accelerator cable that has been extended. All those things combined only allows a few threads on the rod to properly set up and connect the linkage, so now I see where the nut/bolt comes into play. Taking all that into consideration, I've set it up as per the Chrysler "shop class video".It is a cheater for not having the right length slotted rod.
If your slotted kickdown lever is too short you can use this adapter. There are a hundred thousand Mopars out there with a bolt in the slot. It is just a work around. If your throttle goes full open with the pedal and your kickdown adjustment makes the transmission shift properly you are probably ok. Is it right? That's for you to decide.I see. I have the right piece of slotted linkage, but have an an Edelbrock RPM intake and 1406 carb. Originally the car came with a 2 barrel carb and it still has the short accelerator cable that has been extended. All those things combined only allows a few threads on the rod to properly set up and connect the linkage, so now I see where the nut/bolt comes into play. Taking all that into consideration, I've set it up as per the Chrysler "shop class video".
Short of some fine tuning does my linkage look set up correctly? Thanks
I got it Mike. Thanks for the tip.If your slotted kickdown lever is too short you can use this adapter. There are a hundred thousand Mopars out there with a bolt in the slot. It is just a work around. If your throttle goes full open with the pedal and your kickdown adjustment makes the transmission shift properly you are probably ok. Is it right? That's for you to decide.
